Cupboard lighting push switch | on ElectriciansForums
Discuss Cupboard lighting push switch in the UK Electrical Forum area at ElectriciansForums.net
Steviecuk
Essex
Hi all. I've just bought a cupboard push switch to turn the cupboard lights on when I open the door.
It's just a single in-line switch in a plastic housing.
The switch will be switching 240v mains taken from the lighting circuit but what are you thoughts... should I wire and switch the live or the neutral wire to break/connect the circuit?
Cheers. Steve.
Cheers. Steve.
Always switch the Live, otherwise you would leave a Live at the light fitting when the switch is turned off.
How are you planning to connect this switch as they very often have exposed terminals?
I saw those ones but opted for a larger concealed one.
  • [ElectriciansForums.net] Cupboard lighting push switch
Reply to Cupboard lighting push switch in the UK Electrical Forum area at ElectriciansForums.net
Also posted in DIY. strange one in my kitchen. 3 sets of 2-way switched mains GU10 Philips down lighters. ( no dimmers) Have been fine for...
