Curent drain | on ElectriciansForums
Discuss Curent drain in the Auto Electrician Forum area at ElectriciansForums.net
My car battery will go flat, if I leave it connected, within 2 days. If I remove the positive cable from the battery and reconnect after x amount of days it starts no problem.
When I put my multimeter in series it shows a drain of 0.11 amps. When I remove the fuses one at a time the only time this figure reduces is when I pull the battery fuse out.
So is my drain within the battery circuit? Or would the current flow be interrupted anyway?
A current of 0.11A translates to approx. 2.5Ah over a day, or 5Ah over 2 days - if that drains the battery, then the nominal 40Ah or so battery can't be holding that much charge - on the other hand, that current seems somewhat high to me, I'd expect to be able to leave a car for 3 weeks and come back and it start.
Update after re-reading the original post: if pulling all the smaller fuses out doesn't change the current, then (a) are you sure you've found all the smaller fuses, sometimes they are in several locations, or (b) look at the wiring diagram for anything that doesn't have its own small fuse (starter motor?).
i had the same prob on a stag
it was the starter solonoid
loads of carbon had built up around the main contacts
this allowed current to drain back thro the motor windings
No, if so then it would make little difference when you leave the battery disconnected.
Have you a radio with a permanent live? Clock? Another one to check is your alternator.It is connected directly,and i have had them the cause of many a battery drain.You can meter,temp check or sometimes,it is easier to disconnect and measure. The first time i found this,i was fifteen years old,and my mates dad had a Bedford TK tipper with this issue.It had an early Lucas ACR alternator,and on a frosty morning,had proved flat again.On peeping under the cab (no tilt on these!) i noticed the only part of the engine without a dusting of frost,was the alternator! The minor discharge through the windings,heating them up just a tad.Your draw is quite low,so do properly load test your battery.
echo peg's post on the battery test. most garages will do you a load test for free (obviously they will want to sell you a battery).
Reply to Curent drain in the Auto Electrician Forum area at ElectriciansForums.net
Couple of issues facing car owners is "sleep drain" when the car has a new multi function HU that sings and dances .Those buggers kill a battery...
It should give fairly accurate results. Bear in mind your car will probably have a smart charging system, so worth having a read up on those.
