I over heard a story at the golf club earlier tonight about this guy who ordered a kitchen to be fitted and the kitchen got fitted yesterday but earlier in the week the kitchen fitter advised that he get a electrician to remove a cooker switch and replace it with a double socket for the new hob and single oven. so the electrician done exactly as the fitter said, plus leaving the old socket that powered the old extractor.
So today as he was admiring his new kitchen he started looking at the instructions of the oven, hob and extractor and noticed the installation instructions that each appliance had to be fitted with a Double Pole Switch Fused Spur Outlet.
He said his double socket was spurred off a single socket that is mounted behind the oven.
I suggested to the guy that the electrician could mount 2 fused spurs from the single socket (radial) to power both the hob and the single oven and also replace the the extractor socket with a fused spur knowing he had safety features of the fuses in the plugs as well as the spurs.
Is the above paragraph not possible? or should the kitchen fitter who works for a 1 man band kitchen supplier who more than likely supplies 1 brand of appliances know exactly what electrical components the appliances should be connected to while he designed the kitchen.
What are your thoughts?
