current carrying capacity -2nd opinion | on ElectriciansForums
Discuss current carrying capacity -2nd opinion in the Australia area at ElectriciansForums.net
P
pushrod
Hi if you are are running 6mm T&E in plastic trunking fastened to masonry what installation method is this? I would normally use table 4D5 of the brb for T&E but nothing there quite fits so would 4D2A, ref method B and 38amps be the best fit - cheers.
Reply to current carrying capacity -2nd opinion in the Australia area at ElectriciansForums.net
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
