current carrying capacity | on ElectriciansForums
Discuss current carrying capacity in the UK Electrical Forum area at ElectriciansForums.net
essex
evening all working away with no regs etc anyone tell me cable size for 200a 3ph head feeding a 6way 3ph ryfield board singles direct from head to db approx. 1m long cheers
Would you say fitting an isolator to the small plate with knockouts on an aircon unit.the small plate which is left when you take covers off.this is the outside unit .is it bad practice or acceptable
Hi davidanthony41. Your question would have been better off on a new post. Nothing to do with current carrying capacity. Get the mods to move it, or you would delete post 5 and start a new one.
As already mentioned, get the post moved or deleted and start a new thread. Also "a picture paints a thousand words".....
Reply to current carrying capacity in the UK Electrical Forum area at ElectriciansForums.net
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
