current carrying capacity | on ElectriciansForums
Discuss current carrying capacity in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
F
f1ngerz
Can anyone tell me the current carrying capacity of a 400 mm copper, insulated flex with non armored sheath , manufacturer has supplied a table(4f1a) but says two single core cable , rating them at 644A. the cable number from the manufacturer is 1227798371.
Just so you know it will be a group of four cables in a 6x6 metal trunking feeding a 3 phase 630A fused isolator.
Reply to current carrying capacity in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
