Current install cost | on ElectriciansForums
Guest viewing is limited
Discuss Current install cost in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
H
Hundleton1
Hi guys my perants had a 4kw system installed last October on the good rate and are very happy with the results , unfortunately I was unable to do it as well as I was cash strapped at the time, iv been looking and just had notification of my electricity payment going up again so I have to do something, we only have a small house a would not get 16 pannels on the roof, would get 8 to 10 though.
What sort of money would a 2 to 2.5kw system cost now ? I been looking at e current FIT rate and I believe it's 16p ? but I also noticed there is a higher and lower rate depending on the home eficency, is this currently inforce ?
Thanks in advance.
Difficult to say without knowing a bit more about your roof. A 2kWp system should cost around £4,500-£5,000 all in.
You will need to get an EPC rating of at least 'D' to qualify for the highest tariff rate.
- - - Updated - - -
Thanks in advance.[/QUOTE
Where are you in the uk maybe someone on here can advise you
thanks for the advise, im in Pembrokeshire south west wales, iv been looknig into the EPC rating and we are an end terrace stone build 2 bed house, we do have a condensing boiler and double glazing and loft insulation so we should meet those requirements, we have quite a small roof so am not sure how many panels we could get on it.
I went to do a survey last week and the guy had a quote for a 4 kwp at £3500 in vat !!!!!!!
I dont know how this is possible
either a mistake or he was having you on. That certainly isn't possible unless someone's doing a stock clearance or something.
£3,500? He is making a loss on materials before he even things about anything else. The bloke must be having you on.
- - - Updated - - -
Just as a rough idea what would you expect a 2-2.5kwp system to produce a year, we are in the worst part of wales for weather but a rough idea will help me
Reply to Current install cost in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi KungFu Turkey Leg and Mainline Thanks for the link Mainline I will see if they are any help. KungFuTurkeyLeg, as far as I can see the mppt...
Thanks makes sense to me now. We had one of the installers come past and explain everything today and now I can see the woods for the trees ! He...
Recommended Sponsor News
Hi everyone,
