00jona
Please help, I have recently block paved my front garden, I had dug down and removed the soil and was just breaking up bricks that I had found with a small hand held drill/ breaker when you guessed it I got a flash as the chisel went through the brick and into the ground. I dug down to find a black mains cable, this was not mine as I had already taken the time to find mine previously. it was to next doors who's power was still on. I called out western power straight away who came out and got a team out to fix the cable that night. several months later I have been hit with a £1000 bill (ouch). I wish to dispute this on the following grounds and would like to know if I am in my rights too. firstly I was shocked that the cable was only 380mm below ground level (is this ok under a lawn?) the cable had no tape above it or any kind of conduit or sheathing around it like my cable has. when they repaired it they also dug down another 8 inches or more and buried it deeper. if the level was ok in the first place my argument is why did they do this. I do have photo's with the tape clearly showing the depth from ground level. do I have any grounds to dispute this bill? surely I could have just as easily have hit this planting a shrub, also where the cable meets the kerb it was only 300mm from the surface. thanks in advance for any advice fighting the big guys. Matt
