cutoff fuse 60A to 100A? | on ElectriciansForums
Discuss cutoff fuse 60A to 100A? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Dear all,
Just updated a very old fuse in an old house, the cable has been changed from 6mm to 25mm, when i took of the cut-off fuse i noticed that the fuse is only 60A, attempted to change it to 100A, but then noticed that the supply live cable is steel cable and about 16mm, so should i change it to 100A fuse or leave it to the supplier? can 16mm steel cable afford 100A?
cheers in advance
why are you even contemplating changing the suppliers fuse!!!!
its not your property and will get you in serious trouble if some thing was to happen...!! leave it alone and let supplier make their mind up..!
It's more likely to be aluminium but as the other guys have said, do not interfere with the supply fuse!
cant see the problem with opening the meter to change tails or pulling the fuse for safe working but dont think changing the fuse myself is a good idea
just to add all the above is illegal not recomended or considered good practice so dont take any of my advise do as you choose and like me if it all goes pete tong then its only you to blame....
er, cos it's illegal?
Oh, you knew that
As I have said in another post when I was o the books one of our guys was sent to a holiday cottage that had no power, my mate found the fault straightaway, fixed it and did all the tests. The cut out wasn't sealed and as he had a fuse in his van he replaced it so the grockles could enjoy their holiday. Boss rang the DNO to get the fuse resealed and all hell broke loose. My mate and the company narrowly escaped prosecution so I would stay well away from the fuse.
Des,
IMHO it is a bit like well why bother with the DNO at all, just let the sparks look after the National Grid as they see fit.
Once the Electrical Trainee get hold of it and we will have no one else to blame but ourselves when we have nationwide power cuts because some Muppet has incorrectly connected something and taken out a couple of 400kV backbones.
Shame though, it would sort the wheat from the chaff.
a meter engineer takes about half a day to be trained for pto on how to pull a service fuse cant see how a fully qualified spark can be deemed less capable, changing fuse size without knowing the correct info is a different matter but for purely pulling or replacing like for like then its not brain surgery.
Had to replace fuse in own cut out when it blew due to the fact it was original from when house was built in 1950's. The rating was 32amps, ok for back then but house was rewiered previous to us buying it and test sheets said 60 at mains. So they cant have checked the rating for the test sheet. when DNO guy put new digital meter in he wasn't bothered i'd cut seals to uprate fuse to suit modern installation needs. Which was an 80 i'd removed from an old farm submain that week.
The problem is when you allow anyone to pull the fuse you can't be sure that they are are going to replace it with the same one. The DNO's restrict the supply to 19KW for supply/network reasons, if everyone starts upping their fuses and drawing more power then all their calculations go out the window.
I used to think it was just protectionism on their part and why can't a fully qualified sparks pull the fuse and replace it saving the cost/inconvenience of getting the DNO in but having read through the report(can't find the link) I am now more of the opinion that keeping the cutout under the control of the networks is pretty vital.
Allowing anyone else to play around with the fuses is asking for trouble, you, me and all the other guys on here may be sensible enough to pull and replace but how can you then guard against the pillocks who will put 100A fuses in everything?
very valid point and good argument, unfortunately it is nigh on impossible to work around the dno when fuses need removing and if they are not willing to offer free courses or run some sort of authorisation scheme then they should be installing isolators at every property the situation as it stands is simply not good enough.
Reply to cutoff fuse 60A to 100A? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
