Cutting 300mm hole in lath and plaster ceiling? | on ElectriciansForums
Discuss Cutting 300mm hole in lath and plaster ceiling? in the UK Electrical Forum area at ElectriciansForums.net
Blackpool
I have to fit a condensation control fan (PIV) into the hall ceiling. The hole needs to be about 300mm and the ceiling is lath and plaster!
Any tips for cutting the ceiling without damaging the surrounding lath and plaster?
Cheers
Good look above to ensure the whole hole ok to be cut out.
Hoover at the ready, I go slow using "join the dots" method with a drill and sharp pad/jab saw.
I've used bonding over the lathes but you have to wait a while for it to go off enough to cut into it - it was my house though so I got on with something else, marriage I think it was!
Cheers all. PIV unit arrived this afternoon and it requires an oval hole! So holesaws no go!
Think I will give the fine bladed pad saw a go. I also have a rotary tool with a spiral cut bit which might be ok.
Think I might try a test cut towards the middle of the proposed hole first to see how stable it is.
Reply to Cutting 300mm hole in lath and plaster ceiling? in the UK Electrical Forum area at ElectriciansForums.net
