R
rocker
Anyone out there of a structural persuasion? Basically I have a loft I've boarded, the hatch to which is in an 'extended' part of the house (from what I can determine), and to get into the main area of the loft you have to squeeze through some beams or rafters which follow the line of the original roof, i.e. from the extended area, they lean away at a 45 ish degree angle into the main area. There are five or six of them, spaced about a foot apart.
Now then, I'd like to be able to get in and out of the main area without having to squeeze through the gap. Also, I would like to put a drum kit in that area, but there is no way I can squeeze in the larger drums. SO does anyone know if I can add two diagonal supports to the top part of this beam, join them to the adjacent beams to give support, then cut away the bottom section of the beam, thus providing easy access? Or is this just lunacy?
Any help or advice would be appreciated muchly!
