Cycling Voltage on light fixture | on ElectriciansForums
Discuss Cycling Voltage on light fixture in the Lighting Forum area at ElectriciansForums.net
Indiana
I have a fan light fixture which I wired more than a year ago. It has three dimmable LED light bulbs on the bottom which recently started exhibiting strange behavior. Last week the lights started dimming and brightening on a regular cycle, roughly every 5 seconds. The lights will start our bright, gradually fade over a 5 second span, the instantaneously return to full brightness. I pulled off one of the bulbs and checked the voltage at the socket with a multimeter. it is cycling between 100 and 50 V in sync with the light bulb brightness. i.e. when the voltage drops to 50 v the lights are dim, then when the voltage jumps back up to 100 v the lights are bright. (on at 15 amp, 120 v circuit) I have never seen this kind of behavior before. I checked the voltage of another light on the same switch at the socket and it has a constant 120 v (no variability at all).
At first I thought this might be a overloaded circuit, but then I realized the other light is on the same circuit and is not having the voltage variations that this light fixture has. I thought this might be a loose neutral, but again I have another light fixture on the same switch which does not have this problem.
What is causing this? Its kinda annoying, but I don't know how to fix it.
TL;DR
Light fixture with fluctuating voltage, on the same circuit as another light with constant votage. What is the cause?
  • WIN_20201024_22_42_10_Pro.mp4
    20.2 MB
Believe it or not you are right and I bet if you opened the light to get to the box I bet you have a loose neutral
Reply to Cycling Voltage on light fixture in the Lighting Forum area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
Indoors? Is the rcbo dedicated to this, or is it an up or down lights rcbo? 6A? Or something else? I'm a bit surprised if it's a current surge...
