Daisy chaining extension cables? Current leaking to earth? | on ElectriciansForums
Discuss Daisy chaining extension cables? Current leaking to earth? in the UK Electrical Forum area at ElectriciansForums.net
linuxthefish
Hi, I only have one socket to work with and adding others is not an option. Can I safely use an 1 socket 10 meter extension lead, with a 8 socket extension on the end? On the 8 socket extension i have a 6 socket extension lead (with another 1 socket extension) and and a 4 socket extension load. How many extension leads can I add before the 30mA RCD trips? Overloading should not be a problem, I have a 10A fuse in the 8 socket extension.
WALL SOCKET > 10 meter 1 socket extension lead > 8 socket extension > 4 socket extension + 6 socket extension cable (with 1 socket extension attached).
All that's plugged in is IT stuff, few laptops, audio amplifier, projector, fan, 2 40w lights, 3 monitors and a toaster sometimes.
If this is for real and you have no other methods I suggest you look into, say a single 12 way adapter and get someone to put a longer flex on it for you, that way you only have one.
And don't plug a toaster into it with everything else on!
tbh, I had to read that a few times to make sense of it, but it really is a far from ideal setup. I appreciate there may only be 1 socket, but why no at least have it changed for a double? The setup you propose is a huge fire risk, and as mentioned by Biff, the fire hazard is well documented.
This is an electricians' forum so I will give you an electrician's answer:
Instead of running extension leads everywhere you should have the circuit altered to provide adequate sockets on the final circuit.
Never mind 'would it work?', 'is it legal' or 'can I do it?', having enough permanent sockets is the way to go.
... That's if it was even a serious question to begin with - a load of IT gear... and a toaster sometimes!?
Could be a windup!
Maybe he's found a socket thats fed from next door
Nope...
The largest I can find is a 10 way, and even that's expensive.
Why are you asking about the RCD tripping anyway?
"Interruption of Service" fines...
Get a power distribution unit and do not use the toaster!
Power Distribution Unit? I thought they were just bigger and more expensive extension cables...
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Reply to Daisy chaining extension cables? Current leaking to earth? in the UK Electrical Forum area at ElectriciansForums.net
It's a room where someone sleeps, so it's a bedroom. Minimum standards were set in the Parker Morris report in around 1963. Anything built after...
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
