Damaged and plasterboard with some movement. Can it be tiled?
Help please from any tilers.
The plumbers made a mistake and had to rerun pipes after plastering. They’ve now patched the walls up of the shower room like this. Some of the pieces have movement on the wall. The filer is due tomorrow to tile the shower room with 60cm x 60cm porecelain tiles. The holes apparently are being made good in the morning but this will be with just unskimmed plasterboard.
Are there any further problems this can create in terms of the condition of the wall that is being tiled.
Can the cracks be directly tiled over or do they need to be filled?
Thanks in advance.
Damaged and plasterboard with some movement. Can it be tiled? for the Original Article on Tiling Advice Forum
Thanks in advance.
