Danfoss 103 mechanical timer to FP75 programmer | on ElectriciansForums
Discuss Danfoss 103 mechanical timer to FP75 programmer in the Central Heating Systems area at ElectriciansForums.net
bjl
wales
im changing over the old danfoss 103 mechanical timer over to the danfoss FP75 programmer. It is a combi boiler so hot water side wont be used just wanted to check on wiring. The connections are
103 timer common terminal 3 linked to live
'on' terminal 1
FP75 programmer CH on terminal 4
CH off terminal 2
just to check where does cable on timer 103 terminal 1 'on' marked go on the programmer ?? CH on or off??
This programmer may not be suitable, as it has no dry relay contacts. The fp75 has only switch live outputs for CH and HW
Connect it to terminal 4 CH on
Good tip on damaging his boiler......A combi requires dry contacts as already stated. Lee sparks has posted 2 diagrams, one for volt free timer (which is required) and one for the Danfross fp75 which has switch live. (which will not work)
But the OP states that the live is linked to the common of the volt free switch on the existing programmer
I don't know what you mean by "dry contacts" if you mean volt free then the OP already said that live was linked to common on the 103 which means the boiler is mains switched.
So not likely to damage the boiler at all!
I don`t know any combi which works on switch live, all I seen are volt free switching to timer then stat.
The op states this is a timer he has not what was fitted, so link was on backplate
Worcester Bosch combi's all have a 240V switched live for external controls.
The OP states he has an old danfoss 103 in which the L has been linked to common which he is replacing with the new programmer.
Most do Vailant, Worcester, Baxi, Potterton and Glow Worm are the most common ones I wire for BG and all these have switched lives.
The 1st pic I posted is for the danfoss 103 the second is for the danfoss FP75 which the OP says he's replacing the 103 with.
so if the boiler has a 240v switched live which it must if Live and 3 are linked then on the new programmer number 1 from old time clock will go to number 4 on new programmer.
Suggest the op checks this out first against the combi`s manual, to be on the safe side. I don`t want to give out bad info.
If the OP could tell us which boiler he has we can confirm this.
But as me, Lee and Dave have all said if live and common are linked on the clock then the boiler is live switched.
Reply to Danfoss 103 mechanical timer to FP75 programmer in the Central Heating Systems area at ElectriciansForums.net
I have just looked at the wiring diagram on line and there are a lot of internal links which if in the wrong terminal could put 230 volt onto...
Electrician Boiler Fault Boiler Fault I’m hoping someone can help with this boiler problem. Couple have just moved into a house that has a Grant...
