Danfoss CHRONO setting | on ElectriciansForums
Discuss Danfoss CHRONO setting in the Central Heating Systems area at ElectriciansForums.net
Mattressback
Up north
I’ve recently had a new boiler and one of your thermostats installed a Danfoss RET1000 B/M/MS thermostat
Is it normal for the thermostat to fire up the boiler for 3 minutes and then turn off for another 4 or 5 mins and then come back on for another 4mins etc 24 hours a day once it has hit the desired temp setting? The radiators never get more than Luke warm and although thermometers suggest the room is at or close to the desired temp the air never feels particularly warm.
I’ve read through the small installation guide left for me and see a setting called CHRONO is this how this particular setting works? I’ve no idea if the thermostat is set to this setting as I daren't remove the thermostat faceplate.
My question is is this how CHRONO works? And therefore I don’t have a faulty unit more just a decision to make as to if I desire this setting or the old style I’m more used to.
Cheers
I had some Danfoss products in my house. They are over complicated, and would not be my choice. From your description and reading the installers manual, that would seem how ‘Chrono’ functions. I would turn it off. If you goggle the stat , and find the installers manual, it will show you how to do it. Make sure you follow safe isolation first, or ask your installers to do it for you.
Reply to Danfoss CHRONO setting in the Central Heating Systems area at ElectriciansForums.net
U
Smart thermostat causing boiler to short cycle or something else? Hi all, When I use my hive thermostat in the way I think your supposed to...
u0362565
U
The 4 pumps are :- 1. boiler to cylinder 2. C/H and UFH circulating pump 3. UFH dedicated pump after manifold 4. DHW circulating pump. (this just...
