Darren Holdway
Hi, im currently building a panel for a customer using a danfoss fc 51 inverter. I cant get it to run or reverse in auto, when i put it into run or reverse in auto I get a kw and amp value but 0hz. When I run it in jog the motor turns at 5hz as set. The motor also works in handling mode. Any help is muchly appreciated and thanks in advance. I can provide any info needed and pics as the panel is at home with me
