Data and LV cables. | on ElectriciansForums
Discuss Data and LV cables. in the UK Electrical Forum area at ElectriciansForums.net
Bsharp
Has anybody any thoughts on this,
Situation is existing steel trunking 100x100 carrying low voltage circuits dropping into 3 compartment Dado, client required data also installing into Dado, trunking non-segregated and can’t be changed (loads of it) can anybody foresee any issues with installing mt3 for instance inside the steel and running data via this?
obviously a separate trunking would be preferable but the situation doesn’t allow for this. All ideas greatly received!!
If the data cables are insulated to the same degree as he same degree as the V cables I don't see any problems.
Unitrunk do Dividing Fillets.
[ElectriciansForums.net] Data and LV cables.
Reply to Data and LV cables. in the UK Electrical Forum area at ElectriciansForums.net
