J
JUDGE
Hi All
I need to run an ethernet cable from the 1st floor to the basement. The most direct and easiest route is through the existing trunking which has power cables in it. Is it ok to run the cat5e cable in the trunking if the cable is shielded? I assumed it would be, but some of the things I've read on the internet say it wont completely block interference from the power cables. The run is about 15M.
this is the Foil Twisted Pair (FTP) cable I was looking at.
Cat 5e Network Cable FTP Solid : Network Cables : Maplin
Any advice would be greatly appreciated
