Data Cables through my trunking! | on ElectriciansForums
Discuss Data Cables through my trunking! in the UK Electrical Forum area at ElectriciansForums.net
E
eddiecme
I've just *completed* quite a large commercial re-wire part of which was offices on a mezzanine floor. I had ran 50x50 trunking round the top of some rooms with drops down to points. I came back to do some final bits and found the data guys have cut holes in the trunking and ran there cat5s alongside! Where do i go with this one?! They must be breaking some regs
They should be seperate.
Shows how qualified they were to carry out the job correctly.
I would pull them out and tell them not to put them in for good measure
That reminded me of
"and don't do it again"
Life of Brian (graffiti on the wall scene)
[ElectriciansForums.net] Data Cables through my trunking!
thankyou, just what i was after. I was that close to cutting them out, took 2 men 4 days to run all the containment im not standing for them doing that!
Yes I know the feeling
There is something primeval about the feeling as well.perhaps its possibly an in build defence mechanism against those that seek our space (pardon the pun)
,at the least the feeling makes for a lot of anger
Been ther mate,new Tesco.
Heating wiring lads done it in my 2x2, at the weekend when we were off site.
PM gave them 24hrs to remove or we cut them out, we hadnt even put anything in it yet!
The ace up the sleeve is refusal of an installation cert as this is a departure from bs 7671.
Boydy
Reply to Data Cables through my trunking! in the UK Electrical Forum area at ElectriciansForums.net
This charger doesn't support rear entry from the looks, only bottom entry, hence that. Unless they make a white sheathed SWA, I would still need...
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
