i have been asked to install some basic white data trunking in an office at existing socket height . i plan to pull existing sockets through to front of data trunking, add a fused spur and then add another 2 sockets.
the run is only about 9 meters with 1 external corner, 2 internal corners and need to step it down about 4inches to go under window sills..
what kind of trunking will i be asking for in wholesalers and if you have any prefrences in what is easy to work with in steping down and buying the corners.
cheers .. i quoted 200 for the trunking am i going to get poo'd on here, my local wholesaler is part of electra centre if that helps ..
