Day 3 - So what's that bit for? | on ElectriciansForums
Discuss Day 3 - So what's that bit for? in the Electrical Engineering Chat area at ElectriciansForums.net
Moley
Supporter
Pontypridd, S.Wales
Well, this wasn't going to be my day 3 subject but today has been a long day and time is short.
At power stations electricity is generated at one voltage then stepped up for distribution. The generator output is usually around 21kV. National Grid distribute at either 275kV or 400kV. DNOs go up to a maximum of 132kV. So, the generated voltage has to be stepped up to the distribution voltage. This is done via a (bloody big) transformer. So, how does then generator connect to the transformer? Big busbars! As I hadn't planned this post I'm a bit short on good pictures but this is a busbar :-
[ElectriciansForums.net] Day 3 - So what's that bit for? To give an idea of size those supports are around a foot long.
How do these connect to the transformer? Flexible braids :-
All those connections have to be cleaned, Contact grease (known as baby ----) applied, torqued and then ductored. Each joint must have a resistance of 10 micro ohms or less.
Well, that's just the basics. Time is getting on so I'll end it here for now. I'll take some better photos and carry on with this thread soon.
Different companies have different time scales for major maintenance on their GSUs (Generator StepUp Transformers) but every few years the transformer has to be disconnected totally and testing carried out to see if there are any issues. Both HV and LV sides are disconnected (I know technically the LV is not LV but that's how it's refered to) totally. If testing carries over two or more days then just a single braid is reconnected at the end of the day just to maintain an earth overnight.
Reply to Day 3 - So what's that bit for? in the Electrical Engineering Chat area at ElectriciansForums.net
I believe that if some how can go up on your wire size from the transformer to your place it would make a huge difference in your voltage...
Just a small correction..
    • Informative
    • Agree
Ok Dave thanks, no more accidents yet 🙏😂….
    • Informative
    • Winner
Youre in the same boat as me. I was previously with niceic and later on, napit. No issues. I didn't bother finishing my nvq3 as in 2010 during the...
