Hi All,
I've turned up at a job where the tenant needs to change the DB as the face is falling apart and was cut to fit more RCBO modules. Anyway the questions are as follows:
1) isolation, the supplier has been made aware of the change by the property manager so I'm reluctant to cut any tags! Any advice & cost/time on getting EDF to install a DP switch in Knightsbridge? I'm struggling to get a hold of them!
2) Regulation height, as you can see from the images the current board is pretty close to the floor. If changing the board do I need to meet the new regulation height. If so any suggestions for extending circuits to the new height would be appreciated? Most of the circuits are routed from the floor, up 2no 50x50mm trunking and into the DB.
Thanks in advance.
Thanks in advance.
