C
craig1000
Scenario is;-
Single Phase DB-3(for identification purposes) fed from link blocks
Link blocks fed from 100A Isolator and also feed a Single phase Wylex old isolator protected by RCD
Link Blocks consist of CPC---Phase 1---Phase 3-----Neutral
These come from 100A Isolator mentioned above (3 phase but only 2 phases are being used from the Isolator)
The Isolator is not a Switch fuse with Fuses in
This in turn is fed from a 100A Switch-fuse Isolator
In terms of a EICR for the DB schedule asking where DB-3 is fed from will it be the 100A Isolator and if so what is the protective device?
Or will it be classed as fed from the 100A Switch-fuse Isolator and protected by the BS88 100A fuses within?
Thoughts please?
Thoughts please?
