Db Help | on ElectriciansForums
Discuss Db Help in the UK Electrical Forum area at ElectriciansForums.net
W
Welshsparky
Went to an EICR today, Customer requested a quote to upgrade DB,
I have never in my life seen a DB like this, It is a 3036 6 way fuse box with main switch , below this is a 4 way with main switch all built into the same unit, I am assuming this was for storage heaters once upon a time. Does anybody know what these were called? I'm going to have to make a right mess getting a standard dual rcd consumer unit in, Could do with finding something that makes it abit more respectable !
Sounds like at the time, a posh Wylex board, not many about.
Concentrate on the cu change. Get a ten way board, extend cables using crimp or wago's.
Do you know what all fuses are operating? Have you done the EICR yet?
Reply to Db Help in the UK Electrical Forum area at ElectriciansForums.net
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
4K
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
