Hi al
question !!!!
DB1 in house ( dual rcd ) feeding small ccu in garage with swa !!! this in turn will feed a swa to a garden shed!!!
Question !!!
i fully under stand 30ma rcd,s in line is a no no !!! so can i install the garage unit with just a main swith and no rcd/main switch and in turn feed the shed via swa from ccu in garage !!!
Question !!!
because of feed from db1 being on a rcd i can not tt the garage ccu so will have to export the earth from db1 . iunderstand you can do this as long as there is no extranios conductive parts in out buildings also i am going to rely on the rcd in db1 ( house ) to protect all the out side installation!!!! i know that if a neutral earth fault occures it will knock half the board out in db1 but can not see any other way round it !!!
Question !!!!
would you guys and girls approach it in the same manner
thanks
Richard
question !!!!
Question !!!
Question !!!
Question !!!!
thanks
Richard
