DC and AC cables on same tray
J
jimmer
Is this a definate no,no. The Ac cable is to be pvc/swa. is it ok if the there is obvious spacing between the 2 cables (i.e. 50mm spacing)
any help much appreciated
thanks
Nothing wrong with it in 7671 terms as far as I am aware provided both cables have insulation appropriate to the highest voltage present.
Regards
Bruce
