DC cabling protection | on ElectriciansForums
Discuss DC cabling protection in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
digital48
Is there any requirement for DC cabling to be protected
- as it passes through a brick wall
- where it bends and enters/leaves a brick wall
- within a garage between where it emerges from a brick wall and enters the inverter?
you should protect in as it passes through a wall ,it can be clipped direct to brickwork but it has to have DC warning stickers on the cable run ,the DI singles also need to be marked ,brown for posi and grey for neg .
hope this helps you
Reply to DC cabling protection in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
You cant just "avoid" the use of RCD's for nuisance tripping... it will depend on how the cable is routed. (ie buried less than 50mm) What has...
My understanding is it's not necessary unless compromising a fire barrier. Hager instructions: Cable Access: Cable access into the metal...
