Hi there,
I went to a woodworking saw today, long story short, the breaking unit had failed.
Anyway I planned to change the unit, like for like, the unit is a BA9024 which has been superseded by a BA9034 which is fine. Problem is, the motor is single phase, but the tech documents for the existing BA9024 show circuit diagrams for a 3 phase motor. The unit was set up to inject DC over phase and neutral on the current setup, rather than over 2 phases. I am unsure if this what may have caused the existing unit to fail.
I have had plenty to do with motors, DOL and Star delta starters over the years, but not huge amounts to do with DC injection breaking. Should a 230V breaking system be used rather than a 400v system?
I don't wnat to blindly copy what may have been someone Else's mistake when fitting the original.
Gary
Gary
