dc isolators | on ElectriciansForums
Discuss dc isolators in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
O
oddjob
can anybody help
i am fitting 9.8kwts solar pv i need to know what size d/c isolators i req and how many it's been put on a 3phase supply and in 4 strings of 10 panels.cheers oj
One per string, rating determined by string Voc (x 1.15) and Isc (x 1.25). Don't forget, 4 strings into one inverter will require string fuses in pos and neg of all strings.
i am right in saying i add these two figures together. two much paperworkl to think staight.cheers oj
can anybody help
Reply to dc isolators in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all, This may is a little odd and may take some getting your head around but here goes... I measured around half the load current on two DC...
In TN-S systems, you shouldn't isolate the neutral in a 4-pole isolator. Connecting neutrals to a dedicated terminal is acceptable and safe...
