dc motor winding test | on ElectriciansForums
Discuss dc motor winding test in the Australia area at ElectriciansForums.net
uk
i have a possible issue with a dc motor i can only get to the 2 inputs and not to the phisical windings
they dont have any shorts to earth and have good continuity readings
are there any other tests that i can carry out without taking the motor to bits??
Reply to dc motor winding test in the Australia area at ElectriciansForums.net
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
Well at about 9.30 last night I stripped the door card off and found the culprit, cable snapped and end off. So I spent another hour and managed...
    • Funny
