DC Volt stick | on ElectriciansForums
Discuss DC Volt stick in the UK Electrical Forum area at ElectriciansForums.net
You could try wading through Google
Click on the Google link.
12 – 24V Des.
I’m sure I’ve come across non contact DC detectors before, but where? I’ve a feeling they only detected a loaded cable. Pass it’s a long time ago.
The normal Volt stick is triggered by the alternating voltage field so only works on AC. On DC the voltage field is static and so you MIGHT get an indication when moving the probe through the field. You can detect a loaded DC cable using a magnotometer but these are very expensive.
In theory that should work quite easily (!)
Old Tony is probably referring to the 'Stick your finger on it and see if you get a belt' technique.
Reply to DC Volt stick in the UK Electrical Forum area at ElectriciansForums.net
Protection from what? What kind of problem with the inverter is going to be helped by having an RCD on the circuit?
davesparks
These are questions to complicated for a simple answer It depends on many things Cable size Cable length Load type and current Filtering and...
