Hi.
I am after a bit of advice if anyone can help. I got called to a job due to RCD tripping. Ir circuits and fault was on cooker. Disconnected cooker and fault gone from DB. The landlord tried to get the cooker fixed , but appliance engineer couldn’t fix, so he brought a new cooker. Today he had cooker installed but when it was switched on it tripped the rcd. I went back and the cooker was disconnected and I found no fault from the DB, however when I did an ir from switch back to DB I had a dead short neutral to earth. It’s a flat so can’t pull boards up from upstairs so am going back to run a new leg of cable. Has anyone got any idea why it would show a good ir from DB to switch but not the other way around.
Thanks in advance
Steve
Thanks in advance
Steve
