Dead tests on a ring final prior to energising | on ElectriciansForums
Discuss Dead tests on a ring final prior to energising in the Electrical Course Trainees Only area at ElectriciansForums.net
N
newtothis
Testing using a socket tester at the sockets gives me unexpected readings, based on little r calcs,
eg, outside allowed variance
Using the probes on the terminals gives me 'Texbook' readings expected from a new install.
Should I conclude the accessories are dodgy ?
They are DP double gang sockets costing £1.90 from TS
Thanks for any help, Please let me know if anything I've said that sounds stupid.
I'd rather know,,,, I have a thick skin ;)
What sort of variance levels are they?
If you are talking 0.1Ω then switching the switch back and forth and taking the socket tester in and out of the socket a few times may help clean up the contacts. (I often think I need a plug with fine sandpaper on the pins for this purpose!)
If you are talking 1Ω then the sockets are probably rubbish.
https://www.youtube.com/watch?v=zSATFrqlSpg
Have you carried out "end to end" r1, r2 & rn dead tests at the board/CU? That is where you should start.
Yes did that before I connected them to the CU did end to end on each one.
Then figure of eighted r1 + rn tested at every socket same with r1+r2.
did the calc r1+r2 /4 got 0.31
When I removed the socket covers every socket was 0.32 Ohms.
when I went to the sockets they were from 0.31 to 0.70 Ohms
Rocked them about abit.
Sometimes I get confused by decimal fractions, is this the case here ?
Thanks I will revew that.
I carried out IR tests result both >999 for L-N & E-L and N-E 780 mega ohms
I am curious to know why N-E was lower but not too worried.
Reply to Dead tests on a ring final prior to energising in the Electrical Course Trainees Only area at ElectriciansForums.net
