DECC RO Consultation 17th July | on ElectriciansForums
Discuss DECC RO Consultation 17th July in the Green Lounge (Access Only) area at ElectriciansForums.net
Hampshire
This is worth a read through, in case you haven't already. Smells wrong to me, this document was put together 13th July, they've moved very quickly on this haven't they.....just in time for the summer break....
There is no need for a knee-jerk reaction from the industry, there is time for this impact to become clearer, but there does seem to be a disconnect between the rhetoric and the data....no surprise there....
DECC RO <5MWp Consultation 13Jul15
5. Summary:
60. The preferred option is to close the RO to new build solar PV projects at or below 5MW from 1 April 2016. It reduces spending under the LCF and has a positive NPV. This is set out in Table 3.
61. Table 3 does not, at this stage, include the impact of the removal of grandfathering or the effects of a potential Banding Review. It also does not include the risk of deployment that would have come forward under the RO instead accrediting or pre-accrediting under FITs. The first of these could increase the savings under the LCF, while the second would reduce the savings.
by also removing the pre-accreditation thing for FITs first, they're setting it up so that they can also ditch or drastically cut the FIT rate for the above 50kWp FITs without ending up with people pre-accrediting 6 months worth of work.
The STA are gearing up for a reasoned response to all of this. There are DECC workshops in both London and Edinburgh on RO and FIT in August.
If you are not an STA member, please join now and get involved in the concerted efforts to defend the industry. Do not leave it up to someone else. We have already had constructive dialogue at ministerial level.
Remember a lot if the negative briefing appearing in the press may not be emanating from DECC but from other enemies of renewables.
not sure if others have picked up that the Green Deal was also killed off yesterday. Do not have more details as still on holiday in Croatia.
Reply to DECC RO Consultation 17th July in the Green Lounge (Access Only) area at ElectriciansForums.net
