simonspark
I remember when FP(or similar) used to be easy to surface clip. Not as neat as pyro, but not bad. However, in the last few years or more the stuff Ive been supplied with either wants to form it self into a spiral when taken off the drum or kinks in the middle when the outrageous act of putting a 90 degree bend on it is performed. And it also refuses to be dressed properly. And then is impossible to strip back in under 10 minutes.
Would someone please recommend a manufaturer who makes nice FP. Thanks
I always use pirrelli, the outer sheath is stiffer, but saying that others are as well. You may have a make with a soft outer sheath !!. piccollo
Decent FP, please
Australia
simonspark,
piccollo,
