Dedicated ring final used to serve heating panels ? | on ElectriciansForums
Discuss Dedicated ring final used to serve heating panels ? in the UK Electrical Forum area at ElectriciansForums.net
madmaz
Afternoon, here's the proposed setup I am planning to supply 9 off 600w IR heating panels from a ring final circuit
the installation is commercial and the panels will be fitted to a suspended ceiling
a contractor and thermostat will control the heaters
the circuit is fed from a 32a rcbo
in the ceiling from the ring there is a fused connection unit 13a feeding and a 4 way hager click ceiling junction this then connects via the click system to 3 heaters (separate click connections) via 1.5 heat resisting flex
as there are 9 heaters 3 in each row this is repeated 3 times so from the ring there is a fused connection unit feeding each click box the ring legs will be equal due to the positioning of each click unit in relation to the consumer unit
the cables are clipped direct standard 2.5 twin and earth
anyone see any issues as it's slightly off a standard arrangement ?
thanks
The hager klik system is designed to control lighting,I would suggest you contact the manufacturer for approval to use the system for heating or use something else. As they are luminaire supporting couplers 559.6.1.4 prohibits their use for any other purpose.
Just read it thanks for that obvious now incase someone clicks a luminaire to it I suppose, I'll do it using standard plug and socket arrangement I'm looking and modifying a redundant circuit that's the reason I'm contemplating it
thanks
Why use an rcbo when the cable is running above a cieling , ,do the ceiling heater not have high and low setting . Just check the reg on ring final circuits at the back of the byb i sure that it says that ring final circuit should not run for long periods of time on a high load or somthing along those lines but with your set up of about 25amp you may be ok
Looking at the regs, the green book, not the yellow - means I have to walk out to the van to get it, the current carrying capacity is 27A, your rcbo is 32A.
this means your exceeding the rating of the cable before the rcbo trips. follow 'flanders' advice you need to rate this circuit around 25Amps.
What i'd be inclined to do would be to mod the rfc into 2 radials, each @ 20A, feeding 3 heaters each. Then bung in a 3rd radial for the last 3. that would break it down better. ( That's if you can't split the existing into 3 ).
Wtf? Ring finals have been fused at 32A for many many years without an issue, what new change in the rules do you think has de-rated the arrangement to 27A?
Reply to Dedicated ring final used to serve heating panels ? in the UK Electrical Forum area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
How did it go?
