definition of safety circuit | on ElectriciansForums
Discuss definition of safety circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
lurch
Can somone confirm exactly waht is meant by "safety circuit" under "prevention of mutual detrimental influence " in the schedule of inspections please.
thanks in advance
Turn back a page then. It lists types of safety services. Now, I would have thought that a safety circuit would be supplying one of these Safety Sevices, or am I missing the point.:rolleyes:
How easy was that to find:rolleyes:
One thing that is definitely a safety circuit is the wireing of an alarm system AFTER the control unit. The wireing from the CU to the control unit is not part of the safety system.
One thing that is definitely NOT a safety system is wireing from the CU to a smoke/heat detector that operates in its own right (ie no control unit).
Does this help?
Does this help?
yes! many thanks
Reply to definition of safety circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
By the time you've dealt with isolator valves that won't shut off and drain valves that won't open, half a day will be gone before you've removed...
