Delete Old sub-panel? | on ElectriciansForums
Discuss Delete Old sub-panel? in the UK Electrical Forum area at ElectriciansForums.net
ChuckTH
Minnesota
Hi, I'm just wondering if it would be a smart thing to have this old panel removed...? We recently purchased a 50's vintage home. It has an updated 200A service in the basement but the upstairs lighting/outlets are still on this old panel upstairs... -- I know it would likely involve re-wiring the lights/outlets... (I could do a lot of that) - --- It all seems to be 12 awg wire but with those old thin grounds (silver in color - aluminum??) - (The grounds are visible and hooked up in the fixtures but don't seem to come to the panel...?).... OR.... should I consider just "updating" the sub-panel where it sits?
I like things to be "right." What should I be thinking about/considering...?
Thanks for your thoughts!
[ElectriciansForums.net] Delete Old sub-panel?
Chuck welcome to the forum and it seems to me either way would work but if you abandoned the up stairs panel you just have 5 circuits to bring out of your 200 amp panel. If you up grade the upstairs panel the feed coming from the 200 amp panel will need to be replaced with a 4 wire cable instead of a 3 wire and at least you can get rid of that old cloth cable. Good luck
Reply to Delete Old sub-panel? in the UK Electrical Forum area at ElectriciansForums.net
There is nothing inherently wrong with this part of the layout. There is another option that you may want to consider. Those supply conductors...
Hi There How did you get on with your basement project?
