Deleted certificate | on ElectriciansForums
Discuss Deleted certificate in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
london
Hello Guys
Is anyone familiar with the basic NIC Online software, i only ask this because i have been a numpty and deleted the certificate can it be recovered? Their technical services are close this evening as well.
A very good reason why using this type of software is not a good idea
Do they not automatically backup?
Well i am hoping its similar to the recycle bin on you desktop
i am hoping the system is similar to the recycle bin on your desktop. fingers crossed lol
I would suspect that if you have deleted it then it will be unrecoverable. I use the NICEIC Certification Software (NIC Clik software) but even then if I deleted a certificate I can't imagine that it would be recoverable.
Just to clarify was this a draft cert or a completed cert?
draft...eeek
Dont no about the nic software but you can recover deleted certs in easy cert ,
I'm just assuming that you can't recover them. I don't actually make a habit of deleting completed certificates!
That's why I was asking the OP to clarify whether this was a draft certificate or a completed one. I'm still none the wiser about that aspect though.
Why does anyone use the NICEIC software anyway? Surely you would produce enough certificates that easy cert or the like is better value for money? Doesn't the NICEIC charge ÂŁ1.50 per cert or something?
Perhaps because a lot of people insist on NIC certificates. So the only options are purchased pads of certs (which can be overprinted with the likes of Amtech), the NIC online cloud software or the Clik NICEIC Certification Software .
Yes it wasn't a draft
You might be lucky, but the Certsure (Elecsa) one I use, when you click 'delete', it does ask again 'you sure you want to delete?'
Incidentally Chris, I've been unable to access their on-line certificate web site for nearly two weeks now, due to a technical fault they have; Elecsa - Welcome to ELECSA - http://www.elecsa.co.uk/. Are you able to use the NICEIC one then? (Thought they - NIC/Elecsa used the same system).
Cancel my last, just used a different browser, and was able to get to the on-line web page. Got a bit of catching up to do :(
Reply to Deleted certificate in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
CRM SOFTWARE - your opinions on the best few brands please Hi Everyone, I currently use E-Works CRM software and feels it does have good...
plumb_know
P
We wouldn't be at all surprised I have been a QS for 25 odd years.
