Unfortunately last weekend while digging up tree stumps I managed to go through the power cable for the local scout hut. SSE are now billing me £330 for fixing it! However a neighbor thought I might be able to argue it as it's only 200mm below the surface. As it was installed with the scout hut back in the 70s should it have been installed lower?
Unfortunately, the DNOs have their own ways of doing things. It is up to contractors etc to access diagrams of the locations of service pipes and cables before carrying out groundworks.
There is guidance on the depth, and methods, for installation of buried cables on the customer’s side of the meter. These include recommended depths(deeper than your picture) warning tape, etc.
If it’s been damaged on the supply side it’s down to you
As @Taylortwocities said, there's for underground supply cables, certainly as the HSE are concerned.
However the Network Supply companies certainly have their own for ducting & cables. Who installed supply cable? Would it be obvious place for a cable to be run.
That said, £330 is not a huge bill to pay.
What did you do to identify buried services before you started work?
Was this cable in a different location to where SSE told you it would be before you started work?
£330 sounds very reasonable for this kind of repair.
Difficult one then, ideally you should ALWAYS assume there are buried services undergound everywhere until you confirm by way of a cable locating device and cable plans from the DNO that the ground below is clear. I think you may have to take it on the chin and cough up, count yourself lucky you did not penetrate the cable.
^^^ This.
Dig by hand where in any doubt. Also, don't assume underground services take what may currently look to be the most obvious route. They often don't, as what's on top may be very different now to what it was when they were first buried.
Hi,do you own the land that the cable passes through? As in,do you have a title deed or similar?
If so,there may have been way-leave granted,and this will have details on what and where.
The only other point i might add,is your picture of the tape measure,is irrelevant;) who,when and where the cable is,usually,is no guarantee of any stipulated depth,and there is always the chance (and escape clause) that the contractors left 600mm of spoil,over the cable and a dozen trades,scraped it back off :cool:
So, if I understand it, this is a cable that comes from the road, crosses your garden on its way to power the scout hut which is not on your property,
Need more information.
If that is the case, as already touched on, a wayleave will likely be in place.
You may be unaware of this - do you happen to receive a cheque for a few pounds each year from the DNO, but are unsure why?
Unfortunately last weekend while digging up tree stumps I managed to go through the power cable for the local scout hut. SSE are now billing me £330 for fixing it! However a neighbor thought I might be able to argue it as it's only 200mm below the surface. As it was installed with the scout hut back in the 70s should it have been installed lower? View attachment 51380
In the USA that cable should be a minimum of 24 inches to the top of the cable. Higher voltages are 30 inches. Having said that we would have to call ULOCO to come out and find the cable, how deep it is and follow it and put red flagged, he has what I call a tone generator and if we don’t have them to come out and check and we start digging and hit a cable the cost to fix is our responsibility. I know a contractor who didn’t follow the rules and they cut a 500 pair on a fiber optic cable and it cost him a bit load of money plus being fined thousands of dollars. There is signs that say call before you dig
Most DNOs should follow the NJUG guidelines, for footpaths and roadways and a couple like to follow it in soft dig but not compulsory as far as I’m aware especially for a bit of sack shown in the photo. it should also have a tile tape depending on how old it is, but I wouldn’t expect to get it out of it on that. As others have said if it’s your land that’s probably the best best
Try telling them that there is no warning tape above the cable,it could make them more benevolent
Make them prove they have permission for that cable to be on your land
This is excellent advice . My old man drilled through the supply cable in our old house which was in the wall cavity . Northern powergrid tried to charge him and were told the cable shouldn't be in the wall cavity . They didn't pursue the invoice .
Uk
Depth of power cable?
Logix_00,
PEG,
