dermatitus | on ElectriciansForums
Discuss dermatitus in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
OXFORD
As a sufferer of this problem,can anyone recommend a barrier cream ,hand cream and some decent work gloves.
When you have it - Synalar gets rid of it, see your doctor it's prescription only I think. (It's cortisone based)
Then try and prevent it because it does come back.
As a sufferer,as a teenager,the only long term answer is to remove the aggravating cause. In my case,one problem revealed another...
I was working on the farm,shoveling potatoes into a riddler,which involved ----ing the rotten ones to one side. Contact with the ooze from these,caused quite bad dermatitis.
The method used to overcome this,was to wear latex gloves,and the problem got better - then worse...resulting in finding the second of my strange allergic reactions,to latex (Silver,being the other!)
So,with good skin care,and Nitrile gloves,i have been lucky enough to avoid problems since.
A friend of mine,another engineer,had to come off the tools,and go into sales,due to a prolonged ignorance,of what was eventually diagnosed as dermatitis.
Is use o Keefes hand(green tub) and foot(blue tub) barrier cream works very well
its very good
[ElectriciansForums.net] dermatitus
the skin between my fingers and nails is always splitting and bleeding
Reply to dermatitus in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
I always used to use the free forms I found on-line, they were a little bit out of date but still held all the relevant information and were good...
I have since found the 3rd edition of the art of electronics in pdf online. Won't link to it of course, but it's out there. There are many...
