Des | on ElectriciansForums
Discuss Des in the Australia area at ElectriciansForums.net
P
peter 2009
Hi all ,
please i need illustration about DES (DATA ENCRIPTION STANDARD) in details and examples to understand this way of encription :):):)
Reply to Des in the Australia area at ElectriciansForums.net
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
Help joining waste pipe to shower waste please Hi, just a quick question about the standard way you connect 40mm waste pipe to the outlet of this...
dameo220
