Design Current | on ElectriciansForums
Discuss Design Current in the Australia area at ElectriciansForums.net
T
timo
When working out design current i know its P/V = Ib but how do you work this out for sockets?
Is a ring main just 32A
But what about a Radiel that feeds say 4 sockets, 1 spur that feeds 3 light points?
Many Thanks in advance
Timo
you use your design current to work out your fuse rating and then cable size.
In the wiring you are talking of there are set assumptions, hence 2.5mm ring main on 32A breaker.
Please elaborate on your query, are you doing a theoretical calculation?
Cable calcs really. btw sorry im a newbie so still learning allot. :)
Okay i know you need to work out design current before you can chose the cable size and protective device. (along with factors such as insulation etc)
I can work a shower raidel out easy enough.
example
9Kw Shower =
Ib = p/v
9000/240 = 37.5A
Design current 37.5Amps and then a suitable cable to carry that current and then a suitable MCB to protect.
But im a little unsure how you would work out the design current on a socket raidel.
If you had a raidel with 3 or 4 sockets on it with 1 fuse spur feeding 3 100watt lights how do you work out total design current on that raidel.
Unless you know what is being plugged into the sockets you can't, hence the generalization 2.5mm 32A ring, 2.5mm 16A radial etc.
All you can do is work out the 3 x 100w lamps.
Unless as it is a theoretical college question where they want you to assume a max load per socket of 13A
so really it would be 16A as the design current.
Is this what you would use on your paperwork that you give the customer along with diagrams etc when you show your workings (cals) for each circuit
example
9Kw Shower =
Ib = p/v
9000/240 = 37.5A
As we now work to a harmonised voltage you should be using 230 in the above calculation and not 240
therefore
Ib= 9000/230=39.13A
Reply to Design Current in the Australia area at ElectriciansForums.net
Hi tssxrr, I am also doing my assignment on the same topics. would you mind sharing the documents which you have done so I will have rough idea...
Anybody who finds the best electrical training videos please add them to the forum in the training category here please. Copy and paste the URL to...
