Design of Small installation | on ElectriciansForums
Guest viewing is limited
Discuss Design of Small installation in the UK Electrical Forum area at ElectriciansForums.net
C
cuzzy1973
Hi
Any Domestic Installers ,any help would be welcome
Im would like to put in a ringmain,a lighting circuit,and a hob and oven
This is into my new extension.i intend to run an swa cable from exsisting
supply 7metre run,fit new board in extension and run circuits from this.
what size swa cable is correct to use.
How long is a bit of string?
No one will be able to give an accurate answer without a lot more detail. This work is notifiable so unless you are able to test, certify and notify you'll be breaking the law.
Get an electrician in to undertake a proper assessment of your needs and advise you accordingly.
Cuzzy ... you may be amused or peed off with all the indirect answers this is because you haven't supplied anything like the info required ... your having 2 heavy loads fitted too yet no ratings given and we don't know the existing loading on your supply ... really need to get someone in or supply us with all required info.
Reply to Design of Small installation in the UK Electrical Forum area at ElectriciansForums.net
If it is TT then you can use the armour of any of them as CPC but will almost certainly need an up-front delay RCD at the sub-main feed point to...
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
