Design software | on ElectriciansForums
Discuss Design software in the UK Electrical Forum area at ElectriciansForums.net
E.E.I
Hemel Hempstead
Hello,
has as anyone got any advise on which software to use instead of Microsoft Visio, don't really want to pay ÂŁ250 of a product I might use once a year
I only want to be able to import drawings (in pdf format) and mark lighting and switch locations. Would be great if the have the correct symbols for the switches also
Are they raster or vector based pdf's? If vector use Adobe Illustrator, if raster you're on a hiding to nowhere because they were never meant to be edited. Visio isn't very good for importing pdf drawings or cad drawings for editing so you'd do well to avoid.
Mol thanks for the heads up I will check out the Adobe software
Reply to Design software in the UK Electrical Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
EMailed to the forum for you @PCBWay
    • Winner
