B
brightspark109
hello, detached garage wiring.
my plan for this would be to run a 6mm armoured to the garage from the house fuseboard. there are spare ways. there is no extranious bondng to be done no metal pipework etc. garage is brick built and dry.
come off dual rcd board 32a breaker in house, 13m surface run. clipped.
into garage unit.
heres my question?? if i take armoured from existing rcd board do i use a garage unit with rcd as main switch, or do i just get a garage unit with main switch, as rcd protection is from house board???
also i plan to carry out this work in pvc conduit in garage. demand is low. its only for 2 lights and 3 d.so (one for fridge)
using 6mm for futureproof
into garage unit.
