Diehl 4300 16 amp limit? | on ElectriciansForums
Discuss Diehl 4300 16 amp limit? in the Australia area at ElectriciansForums.net
B
Bremner
Has anybody used the Diehl 4300s and confirm wether or not it is limited @ 16amps? A customer of mine would like me to fit a system he has already purchased - 18 x 250w Sharp mono's with this inverter, he is adamant on installing all the panels so will be 4.5kWp. Now as far as I can see from the data sheet this is possible with this inverter (surprisingly) while still limited to 16amps so the system would be g/83 compliant.
Can anyone confirm this?
Thanks.
Reply to Diehl 4300 16 amp limit? in the Australia area at ElectriciansForums.net
