View the thread, titled "Diehl AKO inverter" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
We're based up in the north east and we get our Diehl Ako's from Cleaner Air Solutions
Hi pvman - did you get sorted with an inverter?
We have the Eltek range (which is actually a Diehl AKO - Eltek share manufacturing of this product in Germany). Same warranty etc.
We are also based in the North East so give us a shout if you need some prices.
Sean
Hi we install 3MWp of that Inverter. Good inverter compact and silent. Some problem with a lot of 22000 premium they have a rele problem that disable one of the 3 mppt.
If you want quote we could give to you direct contact.
Reply to the thread, titled "Diehl AKO inverter" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
