diesel leaking from car i bought | on ElectriciansForums
Discuss diesel leaking from car i bought in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
i=p/u
Northern Ireland
hey hi yo, just asking about if any of you gus have had a leak in you tank and how you repaired it. its a plastic tank and im getting reccomended chemical metal, any vies on this wise ones. thanks
well thats why i want it fixed , it aint leaking much but does leave a wee puddle if left static for few hours. have you ever heard chemical metal uses to fix plastic tank.?? this is a bikers question or do you have L plates lol
Chemical metel is ok but your have to do it every couple of months.if it's plastic why not empty your tank out then repair it with fibreglass but make sure where the hole is put a bit of plastic over it then fibreglass then seal job done
cheers gooner but i was inclined fibre glass wouldnt hold with diesel or petrol. i will search on b4 i go buy something in next hour as i have a wee job to do and dont want to leak on her driveway...
Tore up my L plates at the age of 17! I've never had to repair a plastic tank, how did it get holed? Not rust!
That's why you put a bit of plastic over the hole mate.you could even use that glue we use on plastic conduit because it melts the two plastics together then fibreglass it
just two wee slices which i think might of been, i actualy havent a clue... can just about change a wheel and add water, but im getting reccomended chemical metal.
Trust me chemical metel won't solve it for a start it's only for metel hense the name.and it will have to be done ever couple of months that if it will stick to plastic iv used chemical metel but only on oil leaks but the pan was metel.
Chemical metal (Belzona) will not cope with the flexing of a plastic tank.
Belzona is great (we repaired a crusher with it) but not for this job.
the correct stuff is called petro patch. available from most good car accessory shops. might be a different one for diesel. if the leak is near the top of the tank, then don't fill it so full. if its round a fuel pipe, you'll probably have to take the tank off.
Reply to diesel leaking from car i bought in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
After getting my --- kicked by the plumbing twice I was not in the mood for taking prisoners. This time I removed and dismantled the pipework and...
    • Funny
I
Not much water from shower head but high pressure in tap Dear Professionals, could you please advise. I have standard mixer tap in my bath (its...
IrinaPri
I
